CCTV Dome camera compatibility
Hp1
12 Dec 2005
Middlesex
I am purchasing a Annke CCTV system with Dome IP cameras. Annke do not have the mount junction boxes that the dome camera can fix onto (to hide cables).
The Hikovision DS-2CC51D3S camera looks to be exactly the same dimensions and uses the DS-1280ZJ-DM18 junction box.
I was wondering if the same could be used on the Annke dome camera. Unfortunately Annke do not provide fixing hole diameter dimensions,
Harry
hmmm best asking someone that supplies both parts so it can be checked.
Unfortunately unless a its rebranded product its unlikely to fit perfectly if at all.
Hi Secureiam,
I was thinking the Annke product may be supplied by Hikvision as the external dimensions are identical and the units look the same.
Many thanks for your input.
Its possible, but I know bases even for similar looking hik products don't always marry up to different cameras and you have to look at the options for each camera to be certain. Some bases have multiple fixing points for different cameras too.
I guess you could always order one and try it they aren't going to break the bank?
  • Thanks
Reactions: Hp1
