A
ahdsh
So when you fit a CCTV system do you
A. Site the recorder under the home TV?
B. Run the camera cables through trunking/under floorboards
Obviously alarm cables can be routed to an understairs cupboard and the end station but with CCTV needed in the lounge you have to have cables from the room.
They can't be drilled immediately outside or they would be cut so they have to go up at least one floor.
How do you do it?
Also a CCTV DVD is easily burgled therefore removing the evidence?
How do you solve that problem?
How do you do it?
