CCU vs DP switch
25 Oct 2010
London
Probably a silly question, but what's the difference between a 45A Cooker Control Unit and a 45A DP switch? Are they interchangeable?
Thanks,
PR
Size. The ccu won't fit on a single back box and is usually supplied with its own, much larger than twin box (sometimes with a single socket on the cover).
The 45 DP switch is available in single or twin box sizes.
Thanks. So, the single-gang 'CCU' I've had installed is probably just a 45A DP switch anyway. Heh.
Cheers,
PR
If you thought there might be a difference shouldn't you have found out before installing one?
