Would be grateful for some advice. We have a CDA built under, electric double oven, about 6 years old.
When you turn the main oven on, it heats up as normal, orange light goes off as normal when it reaches temperature, then after about half an hour it switches off and the clock also turns off completely. The top oven still works but the main oven wont come back on again for a while. Then eventually the clock comes back on again by itself, showing flashing 0:00. Once you reset the clock you can turn the main oven back on again.
The cooling fan is working.
Any ideas what the fault could be?
Thanks in advance.
Thanks in advance.
