Couple of novice questions related to the standard ceiling height in a new new build so brick courses line up for joists, plasterboards and window sill heights.
1. Are ceiling heights 2400mm or 2475mm to allow for 22mm Weyrock floor, 12mm boarded ceiling and a gap between the bottom of the plasterboard and the finished floor height?
2. If its 2400mm, does this mean each 2400mm plaster board needs cut down to allow room for the floor board & ceiling board?
3. Are ceilings boarded before walls, or walls then ceilings?
