Ceiling insulation ?
7 May 2009
Glasgow
I live in a downstairs flat which doesnt seem to hold the heat much! I have suspended ceiling in the b/r, bathroom and kitchen (wood) there is a cavity of prob 5/6 " between this and original ceiling, can i install some insulation in this space? It would be a bonus if it dulled sound too as even the sound of a sneeze carries from above : -)
thanks, jeanette
You could but I assume you have electrical cable in the ceiling/floor void.
Insulation effects the current carrying capacity of the cable as it restricts the dissipation of heat from them. So you must account for this, generally lighting circuits are okay, but other power and socket circuits will be an issue.
Depending on your door architrave, or shape of the room etc, you might find using insulated plasterboard to the ceiling easier to install, means you don't have to open anything up, and it will help slightly with sound. Also means you don't have to worry about any cables or cutting of plasteboard to get into the ceiling.
