I'm seeking some advice on connecting new light fitting to a pair of ceiling cables. You can see the cables and the light fitting connections at the following URL
http://www.snapfish.co.uk/thumbnailshare/AlbumID=33770950/a=38121274_38121274/t_=38121274 (let me know if you can't open this - it may require you to register with Snapfish, unfortunately).
As you'll see, the 2 ceiling cables are 3-core, each housing a red, a black and a copper earth. The two blacks are identical and purely black.
The new light fitting comes with three 2-core cables, each cable housing a brown and a blue. These come connected to a 4-terminal block. From left to right, terminal 1 is empty, terminal 2 has the browns, terminal 2 has the earth, and terminal 4 has the blues.
The obvious question - how do I connect the wires in the ceiling cables to the terminal block, and do I need to move around the new light fitting connections?
Thanks for any help you can give me.
