Hi
Posted a few days ago about damage to ceiling spot lamps following bathroom flood. Have checked as advised and predictably the lamps themselves are quite black and there is some corrosion.
I will replace as advised but have one problem. The securing screw at one end of the batten doesn't penetrate the plasterboard and is more or less dangling. Aspark did a first aid job afew months ago with alonger screw/bigger wall plug and I have obviously undone all the good work by unscrewing it)
Is there a work around to remedy this problem?
If the new light fitting doesn't conceal the holes what would you advise (probably the same question I guess)
Thanks for your help
cedrich
cedrich
