Hi guys, I have a really daft question . First a bit of history....4 months ago paid a registered sparky 150 quid to install some ceiling fans with lights in place of the standard pendant lights that were there. To cut a long story short, had to get a second sparky out to fix the job he had buggered up( he failed to wire two lights completely and asked me to pay for his driveshaft which allegedly had snapped on his way back to check the job some six weeks later). We are now moving and I have replaced all the lights with the original or new ceiling pendant lights, it was a bit of a nightmare because he didn't mark any of the switched live wires, there were connector blocks everywhere...
All the rest of the house is fine, apart from one of the two lounge lights. The first light has three cables to the rose, consisting of 3 black, 3 red and 3 earth wires, the switch that controls that light works fine as do all the other downstairs lights on the same loop. All apart from these last two which appear to be connected to a dimmer switch(never used it because we had ceiling fans and they don't like being tweaked by a dimmer).
The last light has only one single cable from the ceiling, consisting of one each of red. black and earth cables. I tried the conventional LNE configuration on this last light but the result was it worked via the second conventional switch but was permanently on. That is the dilemna, as there is only this one cable consisting of 3 wires, how does that figure in to the loop? I should add that the other lounge light with the 3 cables is also able to be switched by the dimmer switch, both on and off...My brain is scrambled....
