I have converted about three quarters of the garage to a gym (~3.5m x 4m), it all seemed to be going well…. but for the ceiling I just fitted pvc planks (2700mm x 250mm x 5mm) which were screwed to the joist (600mm centres). I’d accept I wasn’t going to insulate the gym and it seemed an attractive and easy solution. However, 2 months later and the vented portable AC unit has pulled off a section of the tiles. When the AC unit is running opening the outward against the air pressure difference is quite a task so in retrospect it wasn’t such a good idea to leave it like that!
So believe I need board out the ceiling and then screw and glue the tiles back on this time, to avoid issues. And probably fit an air vent to equalise the pressure a bit to avoid anything similar to happening again.
I have already fitted LED light strips just 40mm below the ceiling and they are as low as they can go. So want to board out using the thinnest strongest option, I’ll need some space to actually fit the pvc planks back. With 600mm centres I am concerned about sagging and having the boards fixed solidly to the ceiling to avoid a similar situation. Adding some noggins would be a solution? But if they aren’t required it would be easier.
So does anyone have any thoughts on the best boarding to use and any words of caution or alternatives?
