Afternoon folks,
Question for all you plasterer types.
Where a ceiling has been partially damaged, say by water ingress, and an area of the ceiling needs repairing, how do you go about it?
What I actually mean is how do you remove the damaged area prior to re-boarding and re-skimming? What do you use to cut the boards out? Do you scrim the new board to the existing ceiling and then try and blend the skimming into the new ceiling as best you can or do you try and remove some of the surrounding skim (say and inch all round the edge of the repair) before taping and the skimming to make it blend better?
The reason I ask is that, being a DIYer I've not got any specialist tools for the job. I've therefore just been cutting out the damaged area up to the nearest joist beyond and then using a stanley knife to cut away the board to half way across the joist. However, this is time consuming and painful on the arms and I can't help but think it would be much easier to use an angle grinder or something to provide the cut. It also means the cut would be much neater.
The other issue is blending in. I've found that when replacing a part of a ceiling, unless you remove an inch or so of skim from the ceiling around the hole that you've created, it's nigh on impossible to get a satisfactory join because the existing ceiling is obviously thicker than the new piece of board that you're inserting and therefore you've got a step which needs taping and then blending although blending is impossible without skimming a huge area around the patch (or the whole ceiling for the best result).
Just wondering how you do it and what you use.
Cheers
Fred[/i]
Cheers
Fred[/i]
