Can anyone advise if a celing rose type cable layout is mandatory with a new install or rewire, or at least do the junction boxes need to be easily accessible (i.e. no punching holes in ceilings or lifting carpets?
The reason for my question is that I'm embarking on fitting remote switches to the lights in the house as part of a project to install various home automation, and I need access to the wiring.
These switches "can" work in a 2 wire setup, and simply use the live and switched live at the wall switch. However during my testing of the device on a small test board I knocked up, it did not perform very well and had a few issues when powered inline with the light/load. When I wired the device with access to a permanent neutral and live, these issues went away.
So I thought to myself, no problem Ill install them at the ceiling rose for each room using the permanent feeds.
I removed a couple of ceiling roses (upstairs rooms) and was greeted with just the switched live and a neutral feeding the blocks in the ceiling rose for the lamps (bog standard pendant fittings as we havent got round to changing yet).
This is in a newly constructed extension in the last 18-24 months. The rest of the house had a total rewire at the same time.
I have not yet tried removing the ceiling rose and giving the cables a tug to see if a junction box makes itself present.
Would the junction box being in the loft count as accessible? Not boarded over, but most likely buried under insulation.
I'd just like to be in possession of the facts before I ask the electrician back.
Im at work at present, but when I get back, Ill try a downstairs fitting and see if all the wires are present.
Many thanks in advance for any advice.
