I am looking into fitting spotlights everywhere, GU10, and am considering LED dimmables, on the assumption they are very economic and generate less heat. I think that the 50W standard halogen spotlights require "hoods" or covers over the back to protect insulation and other materials from catching on fire. I have also discovered that there are 240V LED bulbs so no external transformers will be needed. Finally it appears the "standard" halogen is 36 degrees beam angle, but many LEDs go to 120 degrees.
Can you please tell me if I am correct in the above assumptions?
