looking 2 convert are cellar and we were just after some advice on where 2 start and the different methods of doing it or any good websites 2 look at any help would be much appreciated thanks
The first thing to fully investigate is the risk of flooding from either surface water, underground water or damaged services
Then consider the potential problems of dampness Moisture may be evaporating harmlessly from the exposed surfaces of the walls and floor. Covering the walls and / or floor will trap this moisture in the walls and may cause problems.
i'm in the process of having system platon installed in a 35m2 cellar - i bought the materials from pamties.co.uk. cost approx 1500 gbp. we have a drain outlet so dont need pump.
