I posted recently in another forum about how we've started work on converting our 4x3m cellar. While it's a true cellar it is effectively located at the top of a hill which is presumably why it does not suffer too badly with dampness - penetrating damp through solid brick walls only. The plan is to employ some sort of sealed/tanked solution
I was told that ventilation is one of the key problems to solve in order to prevent mould and mustiness and so on. The cellar actually has 3 ventilation grates: 2 at ceiling height directly to the outside at ground level, and another through to the underfloor cavity in another room.
I note that this does already cause a slight through draught, there is a slight breeze coming from under the next room. It made me think that this might be good to encourage. We had thought to put a constant extractor fan in one of the external vents and I'm wondering if we sealed up the other external vent, this would cause more air to be sucked through from under the next room. My thinking was this air is probably going to be a bit warmer and dryer than the outside air, which would aid with condensation.
Or, I could have the extractor fan and block up both other vents. It's an old house so my thought was THIS would then suck air in from the room above, which is going to be warm and dry from central heating.
Any general advice on ventilation concerns are welcome and my rambling text above but here are some specific questions I am considering:
- Is a continuous fan (e.g. https://www.greenwood.co.uk/product/153/unity-cv2gip) sufficient for airflow? We used these elsewhere and they can be run virtually silent 24/7 or boosted if they detect higher humidity.
- Does the positioning of the extractor fan matter e.g. don't put a fan next to another vent, but try and ensure it is pulling air through the whole space? Seems like it would to me
- Is an additional fan helpful, just to ensure constant air movement?
- Am I right to think having warmer/dryer air coming in e.g. from a heated room above, is preferable?
