ok...This is the best description I could come up with - outside skin is standard brick, inside is the larger "solid concrete grey blocks" (Sorry dont know the tech term), will then look to plasterboard (not sure if the foil backed stuff is needed), then skim (that wall) (no electrical on it but there will be a radiator under the window (garage conversion)
Was just curious as to what size was needed as a minimum
