Hi
I've only ever seen rock wool type insulation put in external cavity walls. Having just come across another member's project on this forum I noticed his builder had used celotex boards instead.
I thought (obviously wrongly) that you couldn't use insulation boards as you needed air to be able to circulate in the cavity.
If insulation boards can be used surely they should always be used as rock wool will never achieve the same degree of insulation as insulation boards?
