- Joined
- 22 Jan 2007
- Messages
- 8
- Reaction score
- 0
- Country
I have a Celsia 24LE boiler with no instruction book (it was already installed when I moved in).
The water pressure is getting low, around 0.5, with an red line that suggests it should be around 1.25. This has been a very slow drop over a long period of time, so I'm not concerned that there is a significant leak in my heating system.
I want to top up the boiler, but just can't work out how! I have a large white plastic key, which I presume must be used to turn a valve and top up the water. Where does this go!?! There are three holes in the bottom of the boiler, the rightmost of which is empty, but if I put the key in that hole there is nothing immediately obvious for it to connect into. I think the metal covering on the bottom of the boiler could probably be removed as it definitely unclips at one side.
Has anyone got/seen one of these boilers? Do you know how to top it up?
I've done a fairly thorough web search looking for the instructions, but haven't been able to find anything, so I would greatly appreciate any help or pointers.
Thanks,
Ellie
Thanks,
Ellie
