When I first moved into my house, the loft had a lot of belongings left by the previous occupants that were filthy from a cement/dirt mix falling onto them from the roof tiles. So I knew that being able to stop these cement falls was important for making it a useful storage loft.
I boarded out all the loft floor, and filled the roof with rafter insulation (http://www.wickes.co.uk/Wickes-60mm-Polystyrene-Rafter-Insulation-Board-0-74-M2-Pack-3/p/210020). In addition to insulating, I had hoped the rafter insulation would stop cement falls from getting onto the stored items.
So a couple of years on I have a lot of stuff stored up there - but the cement falls continue to be a nuisance. It's possibly a bit better than it would otherwise have been, but over time the cement still gets through the gaps. So, numerous cement falls on the stored items; cement falling onto the landing every time I open the loft hatch; when I get a suitcase down to pack for a holiday, the first job is hoovering the cement from the outside of the suitcase, etc...cleaning all the stored items regularly would be less than easy as I have quite a lot stored up there, so you have to move some items around to get at others in the eaves, etc.
I had hoped to have a big storage space for which when I take items down, they come out as clean as they went in, and that's just not the case.
Has anyone else successfully solved this sort of problem?
