Good morning. The chimney in my diner was removed many years ago and now there is only an opening where we have put some books and so has its hearth where now there is only a small cement slab. In the rest of the diner there is an old carpet that we want to remove and replace with some tong and groove floating floor. Under the carpet there are timber planks. Basically, I would like to remove the carpet, put some sort of dpm on the little slab of cement, which seems to be flush with the timber planks, cover the slab and the timber planks with insulation before laying the floating floor all over. Would it work? Thank you for your time.
