ve got a concrete slab shed roof with a block work wall around the top.
When it rains, it fills with water.
There is a drainage point but the rise and fall points AWAY from it!
I want to lay a mix of concrete to create a valley and channel the water towards the drain.
What mix should I use?
ratios?
Im thinking of adding CEMENTONE integral water proofer?
Then painting ACrypol on top (when dry)
Any pointers advice on the mix ratio?
ratios?
