How much washing up liquid should I add to a bucket of cement/mortar mix for pointing etc. making it easier to work with.
Brickies who I work with use plasticiser.See alot of builders using this method ?
Problem is - buy a 2-litre can of plasticiser for a small job, and you can't use what's left for washing up.For non structural work, a quick squirt in the water bucket, but for the price you may as well buy the proper stuff
Original, lemon or peach?How much washing up liquid should I add to a bucket of cement/mortar mix for pointing etc. making it easier to work with.
Of course there is, price, every little helpsDepends on the brand. Big difference between Tesco's own and Fairy.
Have you tried? They work on pretty similar principles so a plasticiser should be able to clean dishes....Problem is - buy a 2-litre can of plasticiser for a small job, and you can't use what's left for washing up.
It does not clean the mixer though. Odd.Have you tried? They work on pretty similar principles so a plasticiser should be able to clean dishes....
Does fairy liquid? Not tried that... might be a bit foamyIt does not clean the mixer though. Odd.
