Why do you need to put those exact quantities in at the same time?
If you do, you just tilt the mixer back.
your making concrete. and your ratios will end up grossly innacurate.
3:2:1 does’nt translate in bags as they are graded by weight not volume. you’ll end up with a cement rich mix that will be weak, dry too quickly and be very dusty.
you need to decant your aggregates and cement into buckets first unless you do it for a job and know from experience what you want.
a belle minimix (yellow) should be ideal for what you want. depending on how big the area is.
