^woody^ said:You only clean it once at the end of the day - so the contents don't harden overnight.
You don't clean it between mixes - even if there are long intervals.
linlin said:Thanks for the replies - they've solved the problem.
The next problem is bricklaying! Any ideas on how to build walls with an angle of about 60 degrees?
DIWHY said:You mean 60 deg vertical?
