Hi. What ratio of Portland Cement/ sharp sand/ aggregate would you recommend for building up existing concrete footings of a small bridge? 3m span. The river water has 'undermined' the exposed edges of the footings. Not so much 'undermined' as 'side scoured'. So some of the concrete will be below water level, and need to cure underwater, whereas some will be above water level.
Is there a 'one size fits all recipe that I should use?
Thanks.
Brian
Thanks.
Brian
