Cement stains on Buff riven slabs
1 Jan 2010
Essex
Hi all, help required please...
I recently laid around 40 Buff riven concrete slabs (yellow ish colour) on a cement base, when i woke up the following day and looked out my window at my recent work i was shocked to see light cement stains over some of the slabs (i was careful of not getting muc on the slabs when i laid them - but clearly not careful enough..)
Can anyone advise any option to remove stains, as mentioned above they are only light (there was no actually muc left on the slabs) They are concrete slabs so not sure if using a acid cement/concrete cleaner would be to harsh on the slab..?
They look lovely when they are wet, but when dry not so nice! because of this would a driveway sealer (wet look shine finish) mask these stains if painted this on?
Any help would be great
Don't put brick acid on concrete slabs - well, not neat anyway! A Very watered down mix might be ok if you are quick.
if the stains are slight they may wear off with time.......
Try the sealer on a spare slab first to see if it works!
