Advice please:
I have a conventional heating system from the late 80s - boiler, hot water tank and radiators. This is controlled by a timer (acl switchmaster), room thermostat and tank thermostat (both are the original Sunvic units). With the timer's controls set to Heating and Water, I can only get the heating to come on if I manually operate the Danfoss 3-way valve. Even if the hot water is fully up to temperature, I have to manually pull the lever to the position where the pump starts and the boiler fires up. I don't believe the Synchron motor is at fault. I have replaced this and it made no difference; the old motor also appeared ok when checked with a multimeter. With the actuator removed, the 3 way valve moves easily with just 'finger' force.
The current actuator was fitted in 2007, but it is set on the original Sunvic valve and baseplate.
Should I consider replacing the whole actuator (Danfoss p/n 5933)?
If so, which one is recommended as the 5933 appears to be no longer available?
Could this be a faulty thermostat issue or even the timer? If so, how do I check?
Many thanks in anticipation.
