Cental heating drained, should I still get hot water?
24 Aug 2010
Worcestershire
Hi
I have drained my central heating to fit a new radiator in the bath room.
I have a condensing bolier (British gas badged Worcester unit).
Will I still be able to get hot water while the central heating system and header tank are drained?
Many thanks in advance?
as above, you will only get hot water if you have an immersion heater as the water from the ch circuit is the same as in the coil inside your cylinder that provides heat to cylinder
