On a recent cold night I decided to set the overnight temperature from the standard 5deg C to 15 so the boiler would operate in the middle of the night if it went cold. It had been operating set at 20 when we went to bed and shut off as expected. It was coming down in temperature. I was woken at 2-15 with the heating coming on (as expected). The problem was it ran for about 5 mins and shut down. After only 1min it fired up again and continued cycling like this. It did not run long enough to get the bedroom radiator even warm. The heating system is a bit noisy before it settles down on a normal early morning warm up and this cycling could not be tolerated to see if the cycling time extended and gave some heat out to the bathroom and landing radiators. The thermostat seemed to see it as the system had reached the required temperature.
Is this a software issue in the thermostat or is it faulty and needs replacing. It is only 3 months old.
Normally on reaching the setting temperature rising it seems to cycle as if the differential is too low but the heating system is not noisy so I have accepted this.
Views please.
Views please.
