I have changed the title to dismiss gas causing the problem.
I can understand that if there is a weep on a sealed system then the boiler gauge pressure will eventually show a drop. On my combi the pressure gauge doesn’t move and stays constant until I bleed a towel rail. Then the pressure gauge drops.
I have had this issue for years where the top rail of the towel rail goes cold maybe 2 times in the heating season so requires a bleed.
In September I had a new boiler fitted with the heating going on in anger in late October. Now I am having to bleed around once a month with the top two rails being cold before bleeding. The pressure gauge reads one bar cold once bled after a slight top up. Is the air getting in due to the low 1 bar pressure? When installed, the pressure gauge was rereading around 1.2 bar so didn’t need topping up but as the pressure drops the air appears to be entering faster, but that could be my imagination.
Question. Why is my pressure gauge not just dropping until the towel rail is bled.
