I have a few questions about balancing a central heating system.
The main reason I think that there is a problem is that when both CH and HW is ON, one of the radiators does not get no where near as hot as the others. When HW is off it gets warm, all be it it takes longer than the others and doesn't get as hot.
1) The system has 2 x 2port valves. on the other side of the valve is shut off taps. For both the CH/HW they are both fully open. Is this correct?
2) There is a Mix TRV and non TRV radiators. Should all TRV radiators have there lockshields fully open and controlled via the TRV. Should the non TRV be fully open at the non lock shield end and then temp set using the lockshield?
3) Is self balancing without radiator thermometers easy enough do and how? what would someone charge to do the balancing?
