central heating blow off
1 Jan 2004
what could cause it to blow off into the f&e tank i have changed the mid position valve but is still doing it. thanks
Not much to go on, could be a number of things. Is the water coming in to the F&E boiling hot or cold, is the pump running?? Was it happening before you changed the valve??......Give us a wee bit more details, lots of skilled guys on here , more info and Im sure they will see you right.
its hot water spewing into the tank but just checked the cylinder thermostat and its not clicking off so think this could be the culprate
whats your problem dp im only asking for advice cock
DP hasn't got a problem, try the mirror, this usually reveals most problems.
When you've done that, post all the information about your system as suggested in one of the top three postings on this forum. If you do this we might be able to help, cock.
sounds like he has to me i mean what sort of reply is that"IF YOU SAY SO!!!"all i asked for what a bit of info i know i didnt put all the details of my problem down but hey im only human aswell!
SORRY TO OFFEND BUT cock is a phrase where i come from not a swear word
You come on forum asking for advise. Then you suggest that the thermostat is defective as it is not clicking and without foundation suggest it is faulty. And you have already changed the diverter valve.
Are you asking for advise or are you suggesting what is wrong? Going by the method of fault location, I cannot see you will cure the defect as fault is unlikely to be the equipment.
I would suggest (going by what you have posted and lack of information) system is plumbed incorrectly COCK :D
