I have this intermittent problem with my central heating boiler (Potterton Suprima 120). It runs fine and heats water and rads but when all controllers turn off and the boiler should shut down showing only a constant red light sometimes (more times than not) the boiler doesn't shut down and sits there cycling through its own run/stop sequence determined (I imagine) by its internal thermostat.
Maintenance engineer came round and said there must be a short because the switched live had current even when all controllers were shut down. We have 2 radiator zones plus water so controllers are boiler stat, 1 combined controller and thermostat for upstairs heating, separate controler and thermostat for downstairs heating and hot water time.
Engineer said I must have knocked a nail through a wire! Not possible given where wires run.
Sometimes the boiler does shut down properly - generally when I have changed settings on controller for downstairs heat and hot water and turned heat on that controller to OFF.
I've studied wiring diagrams until my head spins - and I don't think it is a short (installation was professionally done about 6 years ago).
Does anyone have any other thoughts on what might be causing this?
