- Joined
- 8 Sep 2010
- Messages
- 25
- Reaction score
- 0
- Country
Hello folks I just discovered your excellent forum and thought it would be an ideal place for help.
It's a grundfos pump working with a potterton suprima 30L-100L wall mounted fan assisted balanced flue gas boiler. The boiler was installed in feb 2002 and has been working without a problem until now.
The boiler tripped out last night when I had it on the 24 hour setting to heat some water up. The red LED light is flashing and pressing the reset button has no effect.
I turned off the temperature control and programmer but the pump continued to run. It was n't until I turned off the electrical mains supply to the boiler that the pump stopped running. The pumps electrical feed cable comes from the boiler and has an overun on it to continue to pump the residue of hot water when the boiler switches off. This is the only pump in my system.
I left it until this morning then switched the electrical mains supply to the boiler on, the pump started up again and continues to run all the time. Again, turning on the programmer and the temperature control to activate the boiler has no effect. The boiler will not even attempt to fire/spark up. The installation and service instructions says that the status of the boiler is "lockout" as evidenced by the red light flashing two times per second. There are no motorised vlaves in my system if that's any help.
If someone could help me diagnose the problem it would be greatly appreciated.
