central heating/boiler sounds like running water but no leak
7 Jan 2009
Lancashire
Hoping someone can point me in the right direction. I have gas central heating opperated through a back boiler system which is connected to my gas fire.
Yesterday am when the heating came on at 5, it woke me up sounding as though water was running through the boiler pipes in the chimney breast behind my head. I have checked everywhere and there is no water leaking anywhere (that i can see anyway). This lasts for about 10 minutes and then the system goes silent. The radiators are all heating up.
The same happened this morning although this time the radiator in my bed room was only warm 75% of the way up and cold at top.
There is a water tank in my spare room and when the heating first turns on you can hear running water around that area to (this is the opposite side of the house to where the boiler is in the chimney breast). It only lasts 10 minutes and then silence and there is no obvious leaks anywhere.
Was planning to bleed the radiators this evening and see if that makes any difference - or should i just call someone in?
Any help would be appreciated.
Shan
ok so i bled the radiators - one had a lot of air in. Problem now is that since i've done that the radiators are not heating up at all. Definately no air in. Not sure if this is likely to be an unrelated issue or not.
Any thoughts?
go check your header tank i the loft.. the small tank should have water in it. ballcock probly needs athump :D
