Is there a calculator, or a rough rule of thumb I can use to calculate the capacity of my central heating system?
I have a bottle of Sentinel X700 biocide and it says;
I have no idea what capacity my system would be at the moment, so I don't know if I need to use a full bottle to treat the system, and then another full bottle when I refill, or whether half a bottle each time would be sufficient.
Normally I would just put in a whole bottle as all these things seem to say that over-dosing won't cause a problem to the system, however with X700 over-dosing will cause a problem with my wallet, so if I can use just half that is worth knowing!
Cheers
.systems should be dosed at a rate of 1 litre of Sentinel X700 to every 300 litres of system volume
Cheers
