Is it the case that a simple programmer (eg Ikon) does not give direct temperature control to the central heating system? Instead, this thermal control only comes from within the boiler (eg Baxi Solo 3 PFL 50) and the water therein?
If this is the case is it possible for a room thermostat (with suitably rated contacts) to directly switch the circulation pump so that regulation is acheived by the boiler switching off due to the restricted water flow?
Or am I really off track here and thinking about a dangerous scenario?
TIA
Rob
TIA
Rob
