i drained my central heating system and changed a radiator yesterday. today i began to refill the system. i put some water into the tank, it came out of the hose very slowly. then i backflushed the system very breifly. and now as im refilling it, seems as if the water is just staying in the tank, an d not filling the radiators. when open the bleed valves nothing comes out, not even air. im completely stuck, and dont know what to do. i reckon it might be sludge in the system, which i caused when i back flushed it.
is the solution to run the system with the chemical in the tank, or ive seen these pumps on hss, are they the best solution?
any help is very much appreicated
