Looking at having a new heat only boiler fitted but we have a water softener and finding it a minefield when it comes to boiler manufacture recommendations and warranties when using soft water. One of the fitters who has been and quoted said we would need to fit a new water pipe direct from the mains outlet (under the kitchen sink) to the expansion tank in the loft. This comes at an increase cost and the pipe would have to run up the kitchen wall into the loft which is not ideal. Another fitter said it would be ok to use the inbuilt bypass on the softener itself when filling the heating system and then replace the ball valve on the expansion tank with a tap. I questioned if this was safe as the ball valve must be there for a reason (to automatically adjust the water in the tank when required). He just shrugged this off saying if the tank needed subsequent filling we could use the inbuilt bypass again. Help please who is correct. Is it safe to replace the ball valve with a tap and cut off the automatic supply to the expansion tank
