Hi there,
I'm new to this forum but I'm wondering if anyone can help. I have just had my central heating system flushed because the rads had cold patches and I was told that sludge had built up over the years and needed flushing. This is a very old system, must be 20/25 years and probably the most basic setup: oil fired boiler, no zoning (so no motorised 3 way valve to switch between CH and HW), no thermostats except that on the boiler. Despite it's age, the system worked OK apart from the radiator cold spots.
However, since the flushing (by what was supposed to be a professional plumber), the overflow has been leaking. He has been back to it 3 times now and replaced the ballcock, balanced the system and tried further tweaks. It was fine for a couple of hours and then the problem started again. So, I decided to go into the loft to have a look myself. The ballcock is fine (there is no water dripping from it). I part emptied the expansion tank (rusty, yellowy water) to a couple of inches below the overflow outlet, enough so that the ballcock didn't start letting water flow. However, within a couple of hours, the water level has risen and the starts overflowing again. This is without firing up the boiler, in other words, just leaving the system idle. I notice that when I turn the stopcock off at the mains, the water level does not rise. There are 3 pipes in the expansion tank (you guys know this anyway!) - the ballcock assy, the overflow and an outlet at the bottom which I am assuming is from the boiler/pipework. So, it would seem that water is coming in via this pipe. But how can this be with the system idle? Any help you guys can give would be so much appreciated. Thanks in advance.
PS: I've remembered something else about this: while the guy was flushing the system, he asked me if I wanted to pump replacing because the existing one was 13 years old. He put one on and after he left, I noticed hot water spewing from the overflow. The radiators were stone cold. I turned the boiler off and the pump was red hot. I got him back and he said that the pump must be faulty so I went to the local plumber's merchant and bought a brand new one myself. Don't know if this helps anyone diagnose the problem. Thanks
