I'm a newly qualifited plumber who's been asked to quote for a job in a bungalow.
He's having a new back door fitted where there wasn't one before and he's moving the kitchen to the back of the house into the same room. Unfortunately, that causes a problem with the flow and return pipes for the central heating i.e. in that room he wants the radiator and pipes completely removing.
I think I'll have to have two flows and returns coming down from the loft so that the radiators in the rooms either side of the new back door can be heated. I've never had two loops before on central heating, nor worked on a bungalow, so my question is: Is there anything I should know before I quote?
It's a two-pipe system run in 15mm.
Altogether he wants:
1) central heating pipes either side of the back door capping off
2) in new kitchen - radiator/pipes removing, but hot and cold putting in
3) old hot and cold pipes removing from the old kitchen
4) old shower removing (hot and cold pipes)
5) a radiator moving a couple of metres in the lounge
I was thinking of quoting £700...
Thanks in advance, to more experienced plumbers than me!
