Hi, I have a central heating system that uses a back boiler from a wood burner. Today i went to fire it up after we had fitted 2 new radiators that were missing from when we moved in. Started it up and only 1 radiator become hot and then i realised i hadn't bled the system. Did that and got rid of a lot of air.
Started the heating again (lit fire etc) and 3 radiators 9all upstairs) got hot. Then 2 stopped being hot. After a while a rather worrying hissing water spurting noise came from the roof area which on investigation was the expansion pipe spewing water out into the tank.
So stopped heating, mopped up water, cooled the tank manually. Then tried turning pump down but same result.
So have gone from last year having some working rads and no loft issues to having 1 working rad (which seems to work without pump on???) and serious issues.
Please help me... do i have an air lock or could it be the pump?
Jo
Jo
