Hi all
Just wondered if anyone would be able to offer some advice. I have a Baxi Combi 105he boiler and its recently been having a bit of a frustrating issue with it. It seems to be locking out with the 60 degree fault on pump/low pressure light flashing. The issue begins intermittently at first but then happens continuously. I've had an engineer out four times so far and they are able to fix the issue at the time but then it returns once they leave.
On the first visit they changed the PCB. The fault went for a bit but returned the next day.
On the second visit the fault seemed to disappear while the engineer was here, he couldn't find a fault but it returned when he left.
On the third visit the engineer said the pump was fine but there was air lock in the system. He drained the boiler and recharged the expansion vessel which made the fault go away... but of course it returned the next day.
Finally on the fourth visit, they replaced the pump. This also worked for a bit but the fault still returned once he had left.
I have worked out I am able to get the boiler to work for a little while in order to allow us to have a shower by completely draining the heating system out of the radiator drain valve and re-pressurising it, however the fault returns after a couple of hours mainly after the boiler being dormant.
I'm unfortunately not a gas safe/competent engineer so I appreciate this isn't something i'm going to be able to fix myself but is there anything I could suggest/insist the engineer checks on his next visit? I am at the end of my tether with this and kind of losing faith in them especially as I have to wait over a week between each visit for the next available appointment which is little frustrating as it is starting to get cold now.
Any suggestions would be much appreciated!
Thank you in advance!
