Central Heating in an empty property
29 Oct 2015
Hi hopefully someone can help me out with this
I have a property which is up for sale but is currently vacant. I dont want to turn the heating off over winter as it isn't very inviting to walk into a stone cold house.
It is a relatively new house (built 2011) so is fairly well insulated, the boiler is in the garage and there is no water tank in the loft to worry about.
I was thinking of leaving the heating on constant at around 15° to keep the house aired and not stone cold.
Has anyone any other recommendations
Cheers
It sounds like a pretty good idea, but of course this doesn't stop you turning the water off in the property - which you should do if only for insurance reasons.
John :)
Hi John thanks for the info, just so I am clear, I presume I can switch the hot water off completely as the hot water tank is in the airing cupboard. Its an unvented system? Also as the central heating is a closed circuit I should turn off the water at the mains?
Sorry if they are stupid questions but I usually live in my house and dont have to worry about this sort of stuff
Yep, turn the water off a the mains and all will be fine.
If you can spot any unlagged pipes, then sort that before you close the place up. Obviously check the property from time to time just to see if everything is ok.
Any outside taps are at risk of course so lag them well or isolate them if you can.
John :)
With modern boiler you should never turn off the mains power to the boiler as it has frost protection and will turn on when the temperature falls below about 3-5 degrees.
In your case I would time it to be at 15 degrees during the viewing hours say 8 am to 8 pm and not waste fuel overnight.
But then I am a little mean.
Of course if weather gets close to freezing I would leave it on 24/7 but probably at just 12 C.
Tony
