I've been asked to install a brand new central heating system at a friends house. He wants 7 Rads installed, 3 downstairs, 4 upstairs.
I wont be installing the boiler as i'm not corgi, havent done any boilers before so dont wanna mess around with this. I will simply install the rads and pipework all the way to the boiler location and a gas engineer will instal boiler and make final connections.
I've done a bit on rad installs when i was at college, measuring up, installing etc. However i'm a bit unsure on a few things based on what i have seen in some houses and was hoping someone here could advise.
My parents house has 7 rads, however the pipework is all 15mm all the way around the system, flow and return (sealed system). Its only just as the pipes leave the boiler that they are 22mm. After about 2 metres they reduce down to 15mm.
Now i always assumed the pipework was 15mm for flow, and 22mm for return?
Could i do my friends install as my parents house is, 15mm all the way and then 22mm just as the pipework reaches the boiler?
thanks in advance and merry christmas!!!
