Hi all, I have a problem with my Central heating and wondered if anybody here knows the solution. Currently the pump is set on 2 (Out of 3 settings) and with all the rads on only the upstairs will heat. If I turn all the upstairs rads off the downstairs will then heat up. To try and find a solution I then turned all the rads back on and turned the pump up to 3. All the rads then heat up and everythings seems great. Until after about 90mins or so the boiler stops igniting. Once this happens the pilot light/central heating will not fire up for a good couple of hours.
Anybody come up with this type of issue before? I have a gravity fed system with the tanks in the loft. I'm no expert with central heating, Just a bit of knowledge on the basics.
Cheers.
Cheers.
