So I have a Ravenheat HE85T combi boiler (same as CSI85T) and the pressure seems to be reducing by ~0.1 bar every week. This is regardless of whether the boiler is in DHW mode only or DHW+CH mode.
I've checked/ tightened all rads and even looked inside the boiler but I can't see a leak anywhere.
I am now planning to book a conversion to Vaillant Ecotec Pro 28 boiler which is a straight swap after a power flush, so I presume the installer would not dig deeper for leaks.
I've also bought a Fernox F4 leaksealer but feeling a bit scared to use it.
The question is should I add the leak sealer before the boiler replacement so it can run around the system and seal the leak before this boiler is removed?
If the leak persists after new boiler is installed, would adding leak sealer invalidate the generous 10 year warranty?
Thanks for your advice in advance.
