I have a Danesmoor 15/19 oil fired boiler - the central heating works OK but I've noticed that the pressure reading drops from 1.5 bar to .25 bar following the heating being on for some time - on further inspection I have water on the floor in the garage around the boiler
I suspect either the PRV on the boiler has failed OR the pressure vessel in the airing cupboard has failed is causing the PRV on the boiler to trigger
My questions are ;
1. Is it likely to be the PRV or the Expansion vessel that has failed ?
2. The Expansion vessel is a 12L varem , I notice most suppliers pre-charge to 1 bar but this has 0.5 bar written in the pre-charge box on the label - can you get different pre-charge values and would it matter if I use a 1 bar ?
My questions are ;
