Unfortunately, I live in a Redrow house. This means, amongst other unpleasant things, that I sleep directly below the hot water tank, central heating motor etc. That, combined with the generally cheap and nasty construction of the house, means that you can hear individual atoms crashing around in the airing cupboard when you're trying to get to sleep.
When the motor bursts into life, as it’s mounted in the middle of several feet of completely unsupported pipework, you jump out of bed in terror, remembering stories of 50-gallon tanks full of boiling water (directly above your head) crashing through the ceiling and onto the people sleeping below.
So… last night, I went to bed, and the motor was rumbling away above my head. It shouldn’t have been, because the heating had been off for about 2 hours, and the hot water comes on in the morning. I went up to the airing cupboard, and found it happily spinning away, and pretty hot.
As with computers, I decided that a good plan would be to switch everything off and on again in the hope that something, somewhere, would reset. Unfortunately, being a computer engineer and not a plumber, I have no idea what “everything” might be. But I found a couple of boxes (below hopefully).
Moving the little lever carefully to the right and back again on the galvanised box had no effect – however, when I moved the one on the plastic box up and down again… it worked! The motor went off, and stayed off, and now everything seems to be working again.
Could anybody please tell me (a) what the two boxes actually DO, (b) if I need a new plastic one?
Thanks!
Thanks!
