Central heating noises from hell
12 Nov 2019
Norway
Good evening.
I've got some noise problems in my central heating which is driving me effing nuts.
some back story.
I bought this house last year. it had a sentral heating system (Oil furnace). using oil for heating is banned in norway from 2020 (and oil is expensive to burn). so i "upgraded" to a Daikin Altherma LT heatpump (combi unit with intergrated DHW). all fine and dandy so far.
But, the big issue i have is extreme flownoise/drone sound from the piping when the waterpump goes full tilt to keep the preset Delta-T as acceptable levels.
the central heat piping and radiators was kept, and is the original ones from when the house was built (1970).
there are 13 Radiators.. 3 in the basement, 5 in the main level and 2 in the second floor.
pipes are a combination of 3/4, 1/2 and 3/8 Galvanic pipes.
is there anything i can do to combat this issue with me not going completly broke?
i've been thinking of maybe going pex, with manifolds and separate feeds to the radiators?
(atleast the ones that are bothering me the most i.e the bedroom and the ones close to it)
but will that even help?
the pump will put out about 40/l min at max. but will modulate itself as it see fit. the daikin unit has full control of the waterpump. and decides for it self how much flow it needs)
i can also add that there WAS flownoise with the Oil furnace too, but that was a manual Grundfos pump that was set at a low speed. so it wasn't too bad to live with.
